how many access point can IAP205H managed?
May I know how many access points that an IAP205H virtual controller can managed?
Re: how many access point can IAP205H managed?
The recommendation is 128.
Tim Cappalli | Aruba Security
What if i have 185 units of AP? What is the suggestion?
Sent from my Huawei Mobile
Technically it will work, but you should consider splitting into two clusters if possible.
Tim
How should I go about it? is there any guide to deploy this?
To create to clusters, you would need to have two management subnets. Each subnet would be for a cluster.
You can set up roaming between the clusters as well. All instructions can be found in the Instant user guide.
Tim
