Contributor I
how to config IAP RAP3 work with 3g dongle ?
Hi all,
I tried to test IAP RAP3 with 3g dongle (vofafone Huawei K4511) but no luck it doesn't work. it's alway showing "Linkdown"
please see logs below.
3/10/2013 18:24:11 PM    Target: 00:1a:1e:08:50:7f    Command: show cellular status *********************************************************************************************************
cellular status
card     detect     link
Present  detect-ok  Linkdown
USB Modem Information
Parameter      Value
Manufacturer    Vodafone
Product         Vodafone
Serial Number   Driver          (none)
Vendor ID       12d1
Product ID      14cc
and this is my configuration
cellular configure
Type            Value
4g-usb-type
usb-type        option
usb-dev         12d114cc
usb-tty         ttyUSB0
usb-init        AT+CGDCONT=1,"IP","internet"
usb-user        web
usb-passwd      web
usb-dial        ATD*99#
usb-modeswitch  -v 0x12d1 -p 0x14b7 -M 55534243123456780000000000000011062000000100000000000000000000
modem-isp
anyone can help?
Thanks in advance
Re: how to config IAP RAP3 work with 3g dongle ?
Hi.
Full instructions including supported modems can be found in the Instant 6.1.3.4-3.1.0.0 user guide.    It is in Chapter 24: Uplink Configuration.
*ATTACHED TO THIS POST FOR YOU* (read chapter 24 very very good)
aakmit wrote:
Hi all,
cellular status
card     detect     link
Parameter      Value
Product         Vodafone
Vendor ID       12d1
Product ID      14cc
cellular configure
Type            Value
4g-usb-type
usb-type        option
usb-dev         12d114cc
usb-tty         ttyUSB0
usb-user        web
usb-passwd      web
usb-dial        ATD*99#
modem-isp
anyone can help?
Thanks in advance
Please open a support case.  This modem is not on the list of tested/supported so it could require some custom parameters for the RAP3.
I have already use this 3g key with RAP (RAP5) and ArubaOS 6.x and it works !
My settings (for ArubaOS):
  • Device : Other (Any)
  • TTY Device Path : ttyUSB0
  • Initialization String : AT+CGDCONT=1,’IP’,’APN’
  • Device Identifier : 0x12d114cc
  • Device Type : option
  • Modeswitch : -v 12d1 -p 14b7 -M 55534243123456780000000000000011062000000100000000000000000000
  • Dial String : ATDT*99***1#
  • Link Priority Ethernet : 10
Replace APN by your APN Provider
ACMP 6.4 / ACMX #107 / ACCP 6.5
