Occasional Contributor I
how to configure multiple ssid on same network in aruba 103
Re: how to configure multiple ssid on same network in aruba 103
Is this AP tied to an Aruba controller as a campus AP or is it in Instant mode ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
We doesnt have controller, there are 4 standalone devices connected to single network
Hi Victor,
We doesnt have controller, there are 4 standalone devices connected to single network and those 4 devices have static ip addresses.
What type of authentication you are planning to use for those SSIDs?
Are you going to assign a different VLAN to each SSID ?
Thank you
Victor Fabian
Hi Victor,
We are planning to use WPA-2 Personal for authentication and all SSID's are
in single VLAN. Please suggest which will be perfect as i'm beginner to this
device.
Thanks & Regards,
Hari Krishna
+91 9791194338
You can follow the instructions on this video but instead of using WPA2 Enterprise you are going to select WPA2 Personal.(Start watching in 3:09)
https://www.youtube.com/watch?v=9x5uvhn2pHg
Use Network Assigned for the VLAN option or do static to specify the VLAN.
You can repeat the same process for all the SSIDs you want to create.
Keep in mind that the the more SSIDs you have broadcasting on your wireless network this will impact the health of your RF environment.
Is there any particular reason why you want to create different SSIDs ?
Are you planning to have different type access based on the SSID ?
Thank you
Victor Fabian
Hi Victor,
We have 4 floors and each standalone device needs to be configured in each floor in different SSIDs and we need these SSIDs under single network. This is our requirement.
Do you need each device to broadcast all the SSIDs or just one ?
Thank you
Victor Fabian
No i dont need to broadcast each SSIDs.
