how to connect ap365 in iap 207 cluster
I have 207 cluster with 5 access point,ineed to add outdoor ap 365 and i need to mesh that one.
Aju Subair.
Re: how to connect ap365 in iap 207 cluster
The IAP365 does not share the same firmware as the 207, so you need to find the same level of code, but for the IAP365 and upgrade it offline before adding it to the IAP207 cluster.  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/Default.aspx?EntryId=20375
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
I am upgraded the firmware of ap365 but it's not adding to my 207 cluster, once I disconnect the 207 clusters from network its getting up.
firmware details:-
APFIRWARE
IAP 2076.5.1.0-4.3.10_57768
AP 3656.5.3.2
please give me a solution..
Regular Contributor I
You need to upgrade the 207 cluster so that it has the same version as the 365 - all devices need to be running the same version of firmware then they will join.
when I am upgrading the firmware I am getting this reply,"upgrade cannot proceed because of another upgrade in progress".I restarted the cluster but result is same.
Do you have all APs on the network when you see this message? try removing the 365 from the network and upgrade the 207 cluster on its own before adding the 365 back onto the network.
yes, I removed ap365 from the network and restarted the AP 207.after that also same error.
You will need to figure out which one is having an issue, go onto the command line of each AP in the cluster and run the command "show version" to see which version each AP is running. "show image version" will show you which images have been downloaded to the devices.
now this cluster i connected only one IAP 207,i am trying to upgrade that ap firmware.now i reseted the ap and configured as new.still i am getting error when i upgrade,but error  changed "retrieve image failed please save the log in the pop up window".
