how to use activate to configure aruba switch
Can Aruba Activate be used to remotely configure Aruba switch?
Re: how to use activate to configure aruba switch
Activate essentially tells the switch where to go for it's configuration and management, either AirWave or Aruba Central.
Tim Cappalli | Aruba Security
