how to use dhcp scope in latest firmware ?
hy,
i'm trying to use dhcp scope features, but it seems i'm failing apart :(
here is my setup:
i have 3 IAPs:
- 2 SSID
i'm trying to create another one, that would offer IP adresses on 10.2.1.0/24 Vlan 11
i've created a local dhcp scope , assigned it to my new SSID
but trying to connect to the SSID failed ! :(
find attached an SS of my DHCP configuration.
if anyone have a clue ... :)
Re: how to use dhcp scope in latest firmware ?
Did you statically assigned the VLAN ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
here is how my SSID is configured (sorry for the french interface).
see file attached
by the way, french translation doesn't seem to be completed :)
What type of authetnication are you using on that SSID ?
Thank you
Victor Fabian
thanks for your reply :)
i'm using WPA & WPA2 Personnal
without any restriction
Are you able to get an ip address if it an open SSID by any chance ?
Is it happening with any type of device ?
Can you please share your ACL rules attached to that network ?
Thank you
Victor Fabian
hy again :)
no ip allocated even in open mode
tested with my dell laptop (ubuntu 14.04), my smartphone : android 4.4 samsung
same behavior :(
This only happens when you assign a static VLAN with an internal dhcp scope , correct ?
You should change the selection to network assigned instead , I just noticed that
Thank you
Victor Fabian
Thank you
Victor Fabian
Tested on lab using the latest code on a IAP-135 and it worked
Thank you
Victor Fabian
