Contributor I
i have poor coverage for Aruba IAP 205 .
 i have signal strength 70 dbm when the distance between the client and the AP is 6 Meters , using WiFi analyzer ,
please advise
tm
Re: i have poor coverage for Aruba IAP 205 .
Hi, whats the value of the signal (transmit power) ? Do you use ARM?
#AirheadsMobile
Contributor I
i left it as default , the ARM is between 18 and 33 .
tm
so your config didn't should the source of your problem. Two posibilitys: failure during mesurement or AP is defective. Do you have bad user experience ? Is this the only AP in area?
#AirheadsMobile
Contributor I
No its new AP from the packet .
Do you have more than one AP in that cluster, or just a single AP?
Does the AP use external antennas?
tm
205 is with internal Antennas
#AirheadsMobile
Can you connect that client to the AP and see what the client signal strength is?
