Frequent Contributor I
iOS 5 device can't authenticate by using 802.1x
iOS 5 device can't authenticate by using 802.1x but iOS 7 device can authenticate. My customer did try few method to authenticate as below for iOS 5 device:
*   username/DOMAIN name ; password
*   username (without name) ; password
above method cannot be authenticate.
iOS 7 device and any other Android version able to authenticate.
Now the firmware is running 6.3.1.1-4.0.0.1
Please advise.
Re: iOS 5 device can't authenticate by using 802.1x
What does the radius server say?  Start with that...
I have to check with my customer. But my customer used same login user account by using iOS 7 device and Android device doesn't have this problem. It just happen on the iOS 5 device.
