iap 105 failover
I am having IAP setup with 2 IAP 105. Master has IP 10.10.10.2  and slave has 10.10.10.3. My client is connceted to slave iap and client gets ip from vitual controller 192.168.2.0 range. When I try to remove Master IAP from network the slave IAP becomes master. but the client gets around 10 Ping drops.
 i have tested it before with 2 IAPs and have got not more than 2 ping drops. Any specific setting to be done to get less ping drops or it is normal ??
IAP os is latest. 6.2.1.0 - 3.3.0.1
thanks,
Harshad.
Re: iap 105 failover
- Are you doing this test at the same location as before ?
- Are you using the same wireless devices ?
- What type of devices are you using ? Have you updated the drivers?
- You may want to look at your RF environment too
- How far apart are your IAPs?
Thank you
Victor Fabian
Lead Mobility Architect
