Re: iap-205 does not give out ip's
Hi Colin,
It's 6.4.2.0-4.1.1.0_46028.
iAP205,
Please consider upgrading to 4.1.1.7 or 4.1.1.8.  There are alot of fixes that went in, that might solve your problem.
I have the same issue, where do I find this firmware upgrade?
Regular Contributor I
http://support.arubanetworks.com/
You need to have a support account, and then under Software you can find the Aruba Instant code.
ACDX, ACCP, CISSP, CWNA
You can just choose the latest GA or EA code here:  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/Default.aspx?EntryId=21997
I guess I have to wait to register:
Support Portal Error
A critical error has occured in the system. While the IT is looking into it, Please close your browser and try logging after sometime.
Try the link provided by cjoseph, it should allow you to download the firmware without having to login.
I am currently running 6.4.2.3-4.1.1.3 on 15 APs. The one available on the link provided by Joseph is 6.4.2.6-4.1.1.13. To be sure, this is compatable with my IAP-205s?
With thi IAP-205s - I use the Taurus???
yes
