Re: iap-205 does not give out ip's
Thanks CJoseph, just to make sure. You said yes to both the compatablility, and that I use Taurus, correct?
Thanks for your time.
Yes and Yes.
I went through the procces of the upgrade and it was "Upgrading" for several hours. I left work and returned to find the original firmware still in place. Any advice?
What is the filename of the firmware?
Did you use the GUI?
Please try from a wired workstation, if you can...
I used Arubainstant_Taurus_6.4.2.6-4.1.1.13_54918 with the GUI from a a non-wired workstation. Will attempt again at 3pm from a wired workstation if you say this is the correct file. Have to wait until school is out, so there are no interuptions. Thanks.
If you can, please compute the Md5 sum to make sure you got the file and it is not corrupted.  Download the Aruba.sha256 file and open it in notepad.  Compare the md5sum for the device downloaded to the md5sum in the file by using an md5sum checker:
I am still having the same issue weekly with all 15 of my IAPs. I have been keeping track of firmware upgrades and installing them as they are available. Currenty running ArubaInstant_Taurus_6.5.2.0_59123... Any new advice?
Can you identify the ap and get the tech support from it?
It's all the APs..
None of the APs give out IP addresses at the same time? Are the VLANs virtual controller assigned or network assigned in those SSIDs?
