Re: iap-205 does not give out ip's
Network assigned
Was this problem ever resolved?  I am having the same issue.  Need help!  I have both IAP 135 's and IAP 205's.  Current firmware shows:  64264116-5009.  I have learned this only occurs with Windows 7 workstations.  Unfortunately, both my labs are still Windows 7.
Yes, please upgrade to latest conservative release 4.2.4.8. or 6.5.3.2.
Pash
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Will that work for both the IAP 135 and the IAP 205?  I don't want to comepletely break my wireless network.
Regular Contributor I
Looks like IAP-135 onl supports up to Instant code 4.2, so this wont work
http://www.arubanetworks.com/support-services/end-of-life/
_ELiasz
ACDX, ACCP, CISSP, CWNA
4.2.4.8 will work for both
ACDX #420 | ACCA
ACDX #420 | ACCA
Can you please send link to download that version please?
