iap 275 not broacasting
I have IAP 275 not broadcasting instant SSID. The country is UAE. Do you have any suggestion?
Joseph
Valued Contributor II
Re: iap 275 not broacasting
Hi Friend,
Try to bring up by resetting to factory default.
Please feel free for any further help on this
Cheers,
Venu Puduchery,
joseph uae wrote:
Joseph
I don't see approval for the AP275 in UAE:  https://geocompliance.arubanetworks.com/Home/Index/uae
That is probably why it is not coming up.
Thank you for your suggestion. I tried 5 times to factory default but no luck. I will try to use US country.. I hope all is well.
Joseph
Scanned by MailMarshal - M86 Security's comprehensive email content security solution.
Download a free evaluation of MailMarshal at www.m86security.com
It should work with US code :)
Cheers,
Venu Puduchery,
What is the SKU of the IAP?
Yan Liu
Product Manager
Aruba Instant
US: +1 650 996 3520
China: +86 136 212 16844
Sent from my iPhone
