iap cp certificate upload stuck
Thanks to, https://community.arubanetworks.com/t5/Wired-Networks/ArubaOS-Default-Certificate-Revocation-FAQ-Mobility-Access/ta-p/275815, I need to replace CP Server certificate.
show log system shows nothing in IAP ....
Re: iap cp certificate upload stuck
The format is likely invalid. You need a PEM with public and private key plus CA certs. Did you follow the instructions in the FAQ?
Tim Cappalli | Aruba Security
Version of AOS.
To be able to parse a wildcard.  As the cert is a wildcard.
That was the issue.  It needs to be 6.5.0.0-4.3.0.0_######.. from Early Adoption.
