iap not getting firmware
Hello, I have an IAP 105 and it currently has firmware:
6.4.2.3-4.1.1.2_48114
I tried looking for a firmware update by clicking the check for update button and it says no response from server.  This device is just working by it's self and there are no filtering or real firewalls on it.  I'm not concnered if there is really a new firmware or not but that it is not checking properly it would seem.
Re: iap not getting firmware
Staylor130,
You could be running into the "Expired Certificate Issue".  The only resolution is to upgrade the IAP manually.  Please PM me your email address and AP model and I will send you 4.1.1.7
Thanks! Fixed it just fine and before i could get back in to the office to try you had the file sent!
How did you fix it?
Sorry, forgot to reply to this.
I had mentioned my model in the comments and I was sent a PM'd link to the latest firmware.
________________________________
This email, including any attachments, may contain confidential information which is intended only for the use of the individual(s) or entity named. If you received this e-mail message in error, please immediately notify the sender by e-mail and delete it. Dissemination, forwarding, printing or copying of this email without the prior consent of the sender is strictly prohibited.
Thank you, my misinterpretation. I took your statement to mean that there was another way to resolve. I PM'd cjoseph and am already up to date and all is working now.
I am having this issue too on my IAP134/IAP135. How can I go about getting a firmware for these?
Dwayne
cjoseph wrote:
Staylor130,
Please PM me with your email address.
I also have a problem with the automatic update of my IAP-105 with firmware version 6.4.2.3-4.1.1.2_48114
It gives a "received no response from server"
Can you send me a link to manually download the latest firmware and update my IAP's?
Thanks.
HI,
I'm having the same problem with 5 brand new IAPs (Model 103 though). All good in the UI, just won't update firmware.
Could you send me the firmware-files manually also please??
Thanks.
/A
