iap104 external antenna configuration
I am having some problems configuring an IAP-104 with two Aruba ANT-17. i was told to put the values 6 db for 2,4ghz and 5 db for 5 ghz under the external antenna tab. All done but i´m still not decent signals. Am i doing something wrong here? I am using software version 6.2.1.0.
Contributor II
Re: iap104 external antenna configuration
Those are the correct settings for that antenna.
http://www.arubanetworks.com/pdf/products/ap-ant-17_ss.pdf
are you getting any signal at all?  are you using extension cables? be sure all three tails are seated and screwed in well.
Valued Contributor I
Can you snap a picture showing which antenna leads you are connecting to which antenna posts on the AP?
It may also be helpful if you can snap a pic showing how the -17 is mounted and what the intended coverage are is.
Yep,  followed those instructions, im getting signal, but not strong. I´m not using any extension cables. The ANT-17 has 3 cables,but i´m only using 2.( 2 from each for connection to the IAP-104)
On pic left.jpg i am using the right and the middle connector. This antenna is supposed to cover some cabins 20 m straight ahead
On pic right.jpg i am using the left and the middle connector. This antenna is supposed to cover cabins 35m ahead.
I´ll get back with the pic from the IAP-104
One the antenna -- you should use the two outer connectors when attaching to a 2x2 AP as shown below:
On the AP -- make sure you have the antennas connected as follows (labeling on the back of the AP):
For the first antenna:
R0/A0: Radio 0 (5GHz), chain 0
R0/A1: Radio 0 (5GHz), chain 1
For the second antenna:
R1/A0: Radio 1 (2.4GHz), chain 0
R1/A1: Radio 1 (2.4GHz), chain 1
ooh, ok i´m testing this now
So if i understand this right antenna nr 1 will only send 5 ghz and the other 2,4?
Btw i connected this like the picture, but it didnt make any difference, actually seems like the signal got weaker
Correct -- one antenna is dedicated to 5Ghz and both leads must be connected.  The second antenna will be for 2.4Ghz only and must also have both leads connected.   You cannot split the radios connectors to try to make one antenna do both 2.4 and 5 as this cust transmit power in half and also confuses the receiver.
How did you have the antennas connected before?  If they were split then, if anything, the power should have gone up.  Where are you taking your measurement?  Remember that the higher frequencies attenuate more rapidly than the lower frequencies.  As such you would want the antenna with the greater distance to the cabins to be on the 2.4Ghz radio.  Going 30meters then penetrating inside the cabins may be pushing it depending on the thickness of the walls.
If you need both 2.4Ghz and 5Ghz to go to the cabins then you need two APs.  The AP-114 and AP-134 are both 3x3:3 and have the 2.4Ghz and 5Ghz radios muxed on the same connector.
Ok so i should have bought the AP-114 or AP-134 instead. Maybe i should consider replacing the IAP104.
If i use the AP-114 or AP-134 and connect all three cables from each Ant-17, will they both transmit 2,4 and 5 ghz?
I am measuring from the cabins that are 20 m from the antenna nr 1, which is now on the 2,4 ghz (i´ve testet both 2,4 and 5 ghz).
 I am running the IAP on POE, do you it makes any difference with a regular power adaptor you think?
