Frequent Contributor II
iap175 mesh and dhcp
i just open a ticket to tac but i wanna know if somebody else found this issue:
i've a mesh portal iap 175 with a bssid where i untag vlan20 (came tagged on eth side) and here the clients take the dhcp without any issues.
i'va a mesh iap 175 with the same bssid (on different channel) where i untag vlan20 (configured via VC), here the client can connect but never get dhcp,
i connect with my linux laptop and i can see the client asking for dhcp service but noone reply....
on master ap (the mesh portal ap) i execute "debug pkg dhcp" and i can see that the client take the dhcp on bssid successfully, but how can i can make the same command on the mesh one? i see debug commands are only for actual VC.
any idea?
someone have dhcp in vlan over mesh iap?
thanks
Andrea Consadori
ACMP 5.0 and 6.3
Re: iap175 mesh and dhcp
if someone have the same issue -----> bug# 85692
Andrea Consadori
ACMP 5.0 and 6.3
