installing VisualRF, but having a problem with Error 2 loading java VM
Trying to install the lastest VisaulRF, but get a "error 2 laoding Java VM " then its stops.
Try Win8,7, 32bit,64bit, xp all come up with the same error,
Downlaoding a older version for web site still no luck
Help.
Re: installing VisualRF, but having a problem with Error 2 loading java VM
Try running it in compatibility mode for Windows 7.
Tim Cappalli | Aruba Security
Just try, still the same error.
launch anywhere error  (title)
Windows error 2 occured while loading the java VM (Main Message)
Moderator
Which installer of VRF Plan do you have (it's in the file name)?  Is this a first time install?  You could try to install an older build and then upgrade to the latest build (as a workaround).  I uninstalled and reinstalled with the current build and it worked for me on Win8 64bit.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
