instant admin fallback dot not work
admin login integration with a tacacs or radius server.
When I choosed the fallback option and logout, it was not possible to relogin using the internal admin user.
it was not possible to login using my acount (tacacs integration).
is there a way to fix it?
Haythem Kefi
Informatique EBR Inc.
CWNA, ACDX#350
Re: instant admin fallback dot not work
Is the TACAS server still responding to requests during this time? If so, then the built-in admin account would not take effect. The fall back option only works when the TACACS server is not responding to requests.
Yan
