internet connection is stuck on some devices
I'm running total 5 Aruba APs (IAP-93, IAP-105) for wifi environment in our office.
But sometimes some devices (android, windows PC) can not access internet with having connection wifi. This problem is never happened to iOS devices.
At the beginning for using devices, there's no problem for accessing internet, but some times later, the problem occurs frequently.
Can you give me some tips for stable wifi environment?
Valued Contributor II
Re: internet connection is stuck on some devices
HI,
I issue looks client specific, can you come up with scenario when exactly this issue is occurring.
Cheers,
Venu Puduchery,
