Frequent Contributor II
ip-range is too small or mis-aligned and can not be used with client count 250.
I keep getting this error when trying to create a new Distributed L2 DHCP pool:
ip-range 192.168.212.1-192.168.212.254 is too small or mis-aligned and can not be used with client count 250.
I am missing something here? i'm only reserving the first address for the gateway.
Re: ip-range is too small or mis-aligned and can not be used with client count 250.
Distributed, L2 — In this mode, the Virtual Controller acts as the DHCP server and the default gateway. Based on the number of clients specified for each branch, the range of IP addresses is divided. Based on the IP address range and client count configuration, the DHCP server in the Virtual Controller is configured with a unique subnet and a corresponding scope.
Thank you
Victor Fabian
Lead Mobility Architect
