Frequent Contributor II
is it possible to create gre tunnels between an Instant AP and a non Aruba device%3F
Re: is it possible to create gre tunnels between an Instant AP and a non Aruba device%3F
No..it isn't. Although, I haven't tried it but it is more than creating the tunnel with our controller.  It also does more L2/3 functinos in terms of DHCP address space and IP routing.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
thanks Seth,
we have a customer wanting to deploy Instants and pushing all guest traffic back to the core via a GRE tunnel.
We will tell them they will need a controller at the core to terminate the tunnel.
thanks again
Pete
MVP
Could you terminate the tunnels on an instant?
Any idea how many would be more than say an iAP105 could handle?
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
