looking for suggestions for ARM settings on IAP-225
I have a few questions on ARM settings for IAP cluster. 14 IAP-225's users are complaining about poor throughput and degraded connection over time.
It seems that they have many IAP’s on the same channels and the ARM power level is default.
Min tx 18 max tx MAX(127)
Also the setting for ARM scanning, client aware, wide band are enabled why is it not changing the channel. Should I disable client aware? I cant find anything on rf/arm settings or suggestions for IAP’s just for controllers.
Any suggestions for IAP setting?
They have a very open layout almost warehouse like with clusters of tables.
AP’s are 40 to 50 feet apart. IAP’s are 225’s
Re: looking for suggestions for ARM settings on IAP-225
In the newer IAP code (ER) you can now set custom ARM power levels for 2.4 And 5.
2.4 should be min 12/ max 9 and 5 min 15/ max 12
You should start by setting the power to min 9 / max 15 if you still have an older os which only lets you setup the ARM settings for both bands.
I also suggest turning on Broadcast filtering under the SSID profile
Thank you
Victor Fabian
Lead Mobility Architect
Great, I will try that.
keith
Super Contributor I
After you´ve made those changes you could turn off client aware configuration for the duration of a night or so to give all APs the possibility of changing channels.
Cheers,
Chris
Christoffer Jacobsson | Aranya AB
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
