mvk
maximum number of SSID's when an AP is connected to a WLAN controller
Hi all,
I have a quick question regarding the maximum number of SSID's when an AP is connected to a WLAN controller. According to the (http://www.arubanetworks.com/pdf/products/MAT_AP.pdf) there is a max. number defined for stand alone mode.
Could the IAP conversion to a thin AP increase the theoratical number of SSID's like some other vendors have or is it the same?
Thank you in advance.
mvk
Re: maximum number of SSID's when an AP is connected to a WLAN controller
It should be 16, when it is a campus AP, depending on the platform.
