noise-wait-time IAP
How do I view/modify "noise-wait time" on IAP (like I can on campus ap)? This controlls how long high levels of Noise (>-75dBm) will be tolerated before changing channels.
If I can't view or modify this on IAP, what is the default value?
Valued Contributor II
Re: noise-wait-time IAP
HI,
We can neither see nor modify this value. the default value is same as controller (AP). i.e >75 dbm.
Cheers,
Venu Puduchery,
