upgrade issues in IAP cluster
Hi all,
I having issues in upgrading IAP cluster. we are using IAP 105 and it is 14 IAPs in a cluster..
if we upgrade the IAP from 4.0.0.1 to 4.0.0.5 then it is showing "status is not valid"
can any one tell me why I am getting this error? is it known issue?
Valued Contributor I
Re: upgrade issues in IAP cluster
Can you post a screen capture of the screen showing the error? Can you also tell us the complete file name you used for the upgrade?
Hi Marcus
if I remove one IAP from cluster and upgrade using same image file, then it is working fine
