used IAP returns wrong map location
Purchased used IAP's, did a factory reset, and installed ok.  However, IOS location services and PC map applications return wrong address.  I assume it was the previous location for these IAP's.  How do I teach them the right location?
Re: used IAP returns wrong map location
Please see the post here:  http://community.arubanetworks.com/t5/Wireless-Access/Is-skyhook-the-location-provider-Aruba-access-points-use-Is/m-p/238118
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
I didn't see a solution in the link that was responded.  I did see a refernece to "advertise-location enabled in the WLAN SSID Profile"   But I don't find that setting in the virtual controller.  Any other clues?
Advertise-location is not related to what you are trying to do.  In the thread there is a link that says how to opt out of location services by changing your SSID name.
Thanks, but I didn't see a link to what you referenced to opt out of location services by changing SSID.  Please resend the link.
