when the power blackout and resume back again the VC doesn't start and other aruba AP take the VC
i have configured aruba network with four IAP 93 and i have configured an AP to be the VC
i have to reboot all the APs again except the VC to back to work again
soft version:- 6.1.3.1-3.0.0.2_34479
Valued Contributor II
Re: when the power blackout and resume back again the VC doesn't start and other aruba AP take the V
Can you give some more clarity on this.
1. The IAP which was Master (VC) not able join after the power blackout ?
2. you want to have the same IAP a Master (VC) ?
Please clarify. solution for these two requirements is different.
Cheers,
Venu Puduchery,
     Yes..
2-2. you want to have the same IAP a Master (VC) ?
   i dont care which is the VC i just need all IAP to work
thanks for your reply
Can you console the same IAP and see whether it is receiving any master beacon or not. also if possible share the console output of " show log system" and "show election"
this observation will give us some idea about this issue.
Cheers,
Venu Puduchery,
Frequent Contributor II
Here is a document that might help you with the issue :
http://www.arubanetworks.com/techdocs/Instant_41_Mobile/Advanced/Content/UG_files/CustomizeIAPParams/Master_Election_Protocol.htm
If you found my post helpful, please give kudos!
