where can i see radio bands that clients are connected in virtual controller?
Is it possible to see if client is connected in 2,4GHz band or in 5GHz band in virtual controller?
Thanks for all,
I appreciate all your help,
Xavi
Re: where can i see radio bands that clients are connected in virtual controller?
If you log into your VC, click on the clients header, it will expand that section and from there you will see what "type" they are
see below
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
I would like to test "band steering" in "prefer5GHz" mode. Are there anyway to see how client sent less than 8 probes request/auth in the last 10 seconds.
The follow link is the features from band steering:
http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Content/ArubaFrameStyles/ARM/Band_Steering.htm
Xavi
I suggest using client match instead instead of band steering. You will get better results.
What model IAP and version are you using?
http://www.arubanetworks.com/pdf/solutions/TB_ClientMatch.pdf
http://www.arubanetworks.com/resources/clientmatch/
ACDX #420 | ACCA
