Data Center
ARUBA equivalent for HP switch
Dears,
Can you please let me know what is the ARUBA equivalent of HP 4208 VL 72GS procurve switch ?
Thanks, & Best Regards,
Amine
HPE IT Consultant
Re: ARUBA equivalent for HP switch
That would be a Aruba 5406 switch with modules. Maybe a bundle is cheaper
Cheers,
Frank
Life off the wire
Or a 5412 depending on your needs
Cheers,
Frank
Life off the wire
Thank you very much Frank for your prompt response and valuable input. Much appreciated.
Best Regards,
Amine
Hi Mohamed,
No probs.
If you need more help send my an PM
If you like my answer kudo's are nice, an accepted solution is great 😁
Cheers,
Frank
Life off the wire
Contributor I
In my opinion 5406 is more suitable for that needs
