Data Center
Does JD089B HPE X120 1G SFP RJ45 TRANSCEIVER supported with HPE FlexFabric 5940 2-slot switch
I am unable to find below part number on IRIS while it is showing in the document (Link has shared)
https://support.hpe.com/hpsc/doc/public/display?docId=emr_na-c05217097#N1062B
Re: Does JD089B HPE X120 1G SFP RJ45 TRANSCEIVER supported with HPE FlexFabric 5940 2-slot switch
Please Ignore
