Data Center
HPE Comware Lab - Simulator
Hi All,
HCL (H3C Cloud Simulator) is an exciting drag and drop application that allows you to simulate the Comware version 7 operating system. You can create a virtual networking environment to include Comware v7 based routers and switches. It enables you to keep your networking environment virtual or bridge your virtual environment to an external network using the TAP interface.
HNS is a script based model of the same simulator.
Select the operating system from the Drop down menu and download.
HPE Comware Lab (HCL) is under "Software (1)"
HPE Network Simulator (HNS) is under "Software - Tools (1)"
HPE Comware Simulators
The web-based Self paced training for HNS is available externally for anyone and everyone (no logins required)
HNS Web-Based Brainshark Training
The HNS toosl can be integrated with GNS3 for installation and operation of multivendor virtual labs with VirtualBox. Attached is a guide which explains the integration.
NOTE: HP Comware OS devices are now HPE Networking devices.
Jay
MVP
Re: HPE Comware Lab - Simulator
It won't install as it thinks VirtualBox 5.0.14 is less than 4.2.18 and wants me to upgrade.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Well you can always downgrade Virtualbox - I have had success in doing the following:
The simulator wants the environment variable VBOX_INSTALL_PATH latest  virtual box uses  a different name for the same concept -  just copy the path in that variable to this one.
You find this under Control Panel\All Control Panel Items\System then choose the Advanced system settings button -  Choose Environment Variables. For localized versions of Windows it can have other names
I have the same problem, but adding the variable "VBOX_INSTALL_PATH" doesn't work for me. I have installed the latest VirtualBox Version (5.1.26) and HCL 7.1.59. When I start the programm I only see the message "please check your installation of VirtualBox API".
I tried to downgrade VirtualBox to 4.2. but then VirtualBox won't start anymore. Maybe because of windows 10 (build 1703).
Is there a newer Version of HCL available or any other solution?
Hi do you have the latest version of hcl?
its available here:
http://www.h3c.com/cn/d_201410/842486_30005_0.htm
Thank you for the link. With this version it works with VirtualBox 5.1
