Data Center
Tx power
What is the impact of tx power adjustment ?
Re: Tx power
what's your issue? there could be no impact it all depends on your use care and/or current problem
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Re: Tx power
Current problem I have coverage issue . but with another vendor i had an issue like co-channel interfearence when the power has increased . Is there any other parameter needed to be considered when  tx value change ?
Re: Tx power
You need to measure and manage channel utilization when you increase the power.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: Tx power
Hi
Can you give a brief how can i do that (measure and channel utilization)
Re: Tx power
Is this an IAP cluster, or controller-based?
Re: Tx power
Its controller based
Re: Tx power
You should be able to see the RF utilization on the dashboard for all of your access points.
