Data Center
Zero touch provisioning on HPE Comware switches
Would you like to add/provision your new HPE Comware switches onto your network automatically, fresh out of the box, without setting up console access into the switch or typing commands manually to configure credentials and enable remote network management access?
As shown in the topology below, this is definately possible!
The guide to help you with this can be found at
