Education
Occasional Contributor I
Bradford Networks Campus Manager code compatability
I currently am using the Bradford Network Sentry running ver 5.2. I have a 6000 controller running 5.0.3.0 code. I want to upgrade the controller to 5.0.4.1. Has anybody seen any issues with Campus Manager and this version of code?
Re: Bradford Networks Campus Manager code compatability
I am not using Campus Manager, but the mechanism to blacklist and remove blacklist has not changed between 5.0.3.0 and 5.0.4.1, and that is the most important thing for CM. Just make sure that you:
- Do a backup flash on all your controllers
- Upgrade the partition opposite to the one that you are currently booting
That way, if anything does not work you can:
- switch the boot partition
- do a restore flash
- reboot the controller to back where it was initially,.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
thank you for the info. Your knowledge is greatly appreciated.
You are very welcome. Hope all is well with you and the folks there.
