Regular Contributor I
snmp trap granularity with APs
It appears there is granularity with snmp traps for controllers but not with the APs. Just and enable/disable switch. Is there a way to configure which traps get sent and which are suppressed. When we turned on snmp traps for APs our HPOV was flooded with all AP activity. We are only concerned with specific info.
Thanks, Mike
Hi, I had a simular question a year ago. There was no way to only enable a few traps "ap up/down" with out enabling them all.
