Foro en Español
Occasional Contributor I
IAP 315 Power Inyecto JW627A o JW629A
Tengo entendido que el IAP 315 funcionaria ya sea con el power inyector JW627A y JW629A, si en caso opto por usar JW627A , que funcionalidades o problemas tendria?
Re: IAP 315 Power Inyecto JW627A o JW629A
Partiendo de esta información de los Power Injector
  • JW627A: 15.4W (802.3af)
  • JW629A: 30W (802.3at)
Revisando el DataSheet de los IAP315:
For the 310 Series Access Points, the IPM power-save feature applies when the unit is powered by an 802.3af PoE source. By default, the USB interface will be the first feature to turn off if AP power consumption will exceed the available power budget. In rare cases it may be necessary to take additional power saving measures, but in most cases, the 310 Series Access Points will operate in unrestricted mode.
Power over Ethernet (PoE): 48 Vdc (nominal) 802.3af/802.3at compliant source
- Unrestricted functionality with 802.3at PoE
- When using IPM, the AP may enter power-save mode with reduced functionality when powered by an 802.3af PoE source (see details on Intelligent Power Monitoring elsewhere in this datasheet)
- Without IPM, the USB port is disabled and transmit power of the 2.4 GHz radio chains is reduced by 3dB to 15dBm max when the AP is powered by and 802.3af PoE source
Rafael del Cerro Flores
ACMP, ACCP, ACDX#324, ACCX#711
Frequent Contributor I
Buenas,
Si usas el inyector JW627A (802.4af - PoE), el AP funcionaria en "modo ahorro" ya que este AP neceista PoE+ (802.3at).
En modo ahorro, el puerto USB deja de funcionar y la radio de 2.GHz reduce la potencia transmitida. Mas info sobre esto en la pagina 4 del datasheet: https://www.arubanetworks.com/assets/ds/DS_AP310Series.pdf
Un saludo
