Foro en Español
Occasional Contributor I
recommendation max IERP to iap 275, to placed closses
Hi Team.
I want to install an iap 275 in a closed place.
What is the maximum EIRP to configure
best regards
Santiago
Re: recommendation max IERP to iap 275, to placed closses
What kind of closed place and how high will the AP be mounted?  What are the dimensions of the space and what clients are you supplying Wifi to?
Hi Joseph
High 4 meters
Dimensions of the place 15 x 10 meters
best regards
Spanish
El Access point se instalara a una altura de 4 metros
las dimensiones del espacio es una sala de 15 x 10 metros.
Saludos cordiales
You should test the maximum at 9 to 12 dbm, and see if that would provide enough coverage at the extreme edge of the room.
Hi Colin Joseph
Best regards
