Forum Français
How To setup Prefered MASTER VC with AIRWAVE
I would like to setup IAP 207 as Prefered VC ( Master ) I dont Find the Option in Airwave GUI ??
Re: How To setup Prefered MASTER VC with AIRWAVE
Hi Richard,
In french or english ?
Do you using IGC mode on AirWave or Template for IAP ?
ACMP 6.4 / ACMX #107 / ACCP 6.5
We are using IGC
It is under the AP specific configuration.
I don't find this parameter !!
on IGC
Go to Access Points Menu (and select your access Point)
and there is the option "Preferred Master"
ok  My airwave is in french and the command  is  :  " Point d'accès principal Favori "
Is possible to setup multiple prefered VC master ? , for example , all 325 access point  and only  AP 325 could be prefered Master VC in the Cluster ?
it is better to use english interface for AirWave ;-)
Yes, it is possible to have multiple prefered VC Master
You can look on IAP VRD guide
