Forum Français
Occasional Contributor I
How can I put two IAP clusters on the same subnet
I have a case where I must put two IAP clusters on the same subnet.
Since IAPs of cluster A and IAPs of cluster B are connected on the same switch, I can configure an ACL that prevents communication between the 2 clusters.
Can I configure this ACL with just IP address ?
Thank.
Jean Maurice
Re: How can I put two IAP clusters on the same subnet
I will just say that two clusters are not designed to be on the same VLAN.
IAPs locate each other via broadcasts and I'm not sure how you would block a broadcast on a a layer 2 segment...
Thank's a lot Colin, I'll try to do it and I'll come back later on this topic.
Jean Maurice
AFAIK this is not possible nor supported
Jmi - Aruba Employee - ACMP - ACCP - ACEAP - Add Kudos if this is helpfull !
