Forum Indonesia
Aruba IAP 205
We have deployed IAP 205 for a Villa & it found working.
In this villa, automation controller(running with  HDL software) is deployed from other vendor.
But through wired connections we can able ping that controller & also through other wifi connection/device(TP-link,D-link) the controller is able to sync with the devices and displays the details.
In the case aruba wireless connection only we can ping that controller but it is not able to sync.
Refer the attached scenario
Anyone knows why it has happening...Suggest us to fix this issue.
Re: Aruba IAP 205
Hi sandeep,
Try to play around with broadcast filtering feature and mDNS feature in IAP.
