BLE beacons, sensors, tags and third party RTLS platforms
Have a customer that can't use an off prem cloud based solution so Meridian is out.
Does anyone know if/how our beacons, tags, and sensors can be used with a third party vendor? We are currently passing through other vendor tag chirps to other vendors on premise servers, but would like to know if we can leverage Aruba hardware for this.
Re: BLE beacons, sensors, tags and third party RTLS platforms
Aruba Tags can only be tracked with Aruba WLAN infrastructure.
You are correct that asset tags from 3rd party partners (such as STANLEY) can also be tracked with Aruba WLAN (Access Points).
Community Manager
To clarify: ArubaOS 8.x will be able to support listening 3rd party BLE tags in the upcoming months. Technically possible, but ArubaOS support is not yet available. Until then, Aruba Tags is the only option against the Aruba WLAN deployed for location services.
http://docs.meridianapps.com/category/386-asset-tracking
Occasional Contributor I
Hi Ozer,
Any 3rd-party BLE tag support available yet ?
-Mohammad
