Frequent Contributor I
How to ensure great position on map with beacons
Hello Aruba Team,
I have beacons deploy on my enviroment but the position (the blue dot) is not show accurate, I follow the instruction, each beacon is 12m to each other.
do you have any suggestion, hope your comments,
regards!
Re: How to ensure great position on map with beacons
Hi Javi12
In my experience I put them every 8-10 meters and on a corridor in open spaces and the location in general is good, it would be necessary to check what type of construction or building you are placing the beacons, height, etc.
Check in this document the types of installation recommended by Aruba to see which one best suits your requirement: https://community.arubanetworks.com/t5/Validated-Reference-Design/Aruba-Beacons-Validated-Reference-Design/ta-p/249198
Regards
is in indoor space  specifically office enviroment.
