Occasional Contributor I
AS-100 BLE sensor documentation
Hi there
i have just set up an AS-100 BLE Sensor
this morning i was able to login into console with the beacon app
but it's no longer possible, i receive "Console Error" ans "Timed out" messages
I'm looking for documentation about this device but all that i can find is the Installation Guide
Could someone provides me with a command line configuration guide please ?
Best regards
Pierre
MVP
Re: AS-100 BLE sensor documentation
Pierre,
The AS-100 should be provisioned and configured with the 'Beacons' app that is available from the Apple App Store. Configuration is done from the Meridian App platform (edit.meridianapps.com).
CLI configuration is not recommended, nor supported.
Please make sure that you updated the Beacons App to the latest version, and you are close to your sensor (within few feet/meter). If you have another IOS device available, it may work to retry with that. If you still have problems that the Beacons app does not communicate properly, please contact the HPE Aruba TAC.
Herman
If you have urgent issues, please contact your Aruba partner or Aruba TAC.
