Occasional Contributor I
Aruba Beacon Specifications and Installation Guide
Hi Team,
Can you provide me the specifications and installation guide for the Aruba Beacon?
I particularly need the following information:
1. Beacon coverage
2. Maximum number of devices detected per beacon
3. Past deployment for the Aruba Beacon.
Appreciate your support!
Ricardo
Re: Aruba Beacon Specifications and Installation Guide
Please contact your Aruba account team.
Tim Cappalli | Aruba ClearPass TME
@timcappalli | ACMX #367 / ACCX #480 / ACEAP / CWSP
Thanks Tim,
Will check with the Aruba Account's team.
Ricardo
