MVP
Can i set the distance/range of BLE tags (Battery powerd)
Hi AirHeads,
Can i set the distance/range of BLE tags (Battery powerd)?
Please advise,
Thanks.
Me
Re: Can i set the distance/range of BLE tags (Battery powerd)
Proximity beacons can be changed. Location beacons are auto power based on the map and other calculations.
Tim
Tim Cappalli | Aruba ClearPass TME
@timcappalli | ACMX #367 / ACCX #480 / ACEAP / CWSP
MVP
Thanks for the info,but in a big retail store with different halls (rows) how do the BLE tags dosent effect client devices on another row?
please advise.
It's all apart of the location calculation in the app. It's dynamic.
Tim
Valued Contributor II
Here Proximity beacons require power control coz, we will push notifications based on the proximity so there is a possibility of deploying proximity beacons at each row with in the hall and it should not overlap with other proximity beacon coverage.
We need one location beacon to cover a hall , one location beacon will cover approx 2500 SFT ( or one location beacon can handle approx 70 clients)  hence we don't deploy location beacon on every row with in the hall but we need atleast 3 beacons to triangulate and estimate the location.
Hope you got some more clarity on this.
Please feel free for any further queries on this.
Cheers,
Venu Puduchery,
MVP
http://community.arubanetworks.com/t5/Validated-Reference-Design/Aruba-Beacons-Validated-Reference-Design/ta-p/249198
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACMP
[If you found my post helpful, please give kudos!]
