Occasional Contributor I
Connecting AP-ANT-25A to AP224
The Aruba AP224 has ANT0, ANT1, ANT2 connections for the Antenna.  The AP-ANT-25A only has 2 connections:  -45' and +45' .  Does it matter which one is connected to which connection?  Is this antenna compatable with this access point?  Thanks
