Contributor I
Does Aruba Controller supports integration with Elitecore?
Hi All,
can you please help me with below question.
Does Aruba Controller support integration with Elitecore plateform for Accounting, Authentication and  policy enforcement?
If yes, Then how it will happen in detail. How msg will flow from controller to Elitecore AAA
Many Thanks in advance,
BR,
Prabhat
Re: Does Aruba Controller supports integration with Elitecore?
The controller is EAP agnostic so if the solution supports standards based authentication protocols, you shouldn't have any issues.
Sent from Nine
Tim Cappalli | Aruba ClearPass TME
@timcappalli | ACMX #367 / ACCX #480 / ACEAP / CWSP
Contributor I
Hi Nine,
thanks for your reply.
do you have any details call flow or network diagram how it looks like.
BR,
Prabhat
