Import floor plan to Aruba Controller
Hi, experts.
Please I need a help with this question.
Is it possible to import a floor plant to Aruba Controller or I need to use Airwave?
Thanks.
Re: Import floor plan to Aruba Controller
What version of code are you running? Visual RF was removed from the controller in 6.3
Tim
Tim Cappalli | Aruba Security TME
