Is it possible to export the Internal DB to modify using excel?
I am not sure if i am in ther correct area...I was wondering if it is at all possible to export the Internal DB out of the controller so I could modify it using excel. I have a 3600 controller. I know how to export it but how do i get that off the controller? Thank you for your help and if i am in the wrong place i am sorry.
MVP
Re: Is it possible to export the Internal DB to modify using excel?
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/importing-CSV-file-to-internal-DB/td-p/78152
Thank you
Victor Fabian
Lead Mobility Engineer @ Integration Partners
Ok Thanks for that but thats not what i am looking for. I am trying to EXPORT what is already in the Internal DB not import.
Recommended note++ or editplus for edit
